Aluminium Grab Rails
Pancho
Segelnummer: 3344
Båtnamn: Pancho
Has thanked: 2 times
Been thanked: 2 times
Inlägg av Pancho »
Hello everyone. Unfortunately one of the aluminium grab rails on my coach roof has been damaged and I need to replace it. The photo is before the damage!
Are the original parts anodised or just plain aluminium? I want to make sure I get something that matches.
Thanks and Happy Christmas to all.
Bilagor
James Baker
IFe "Pancho" SUI 3344
Based in Portsmouth UK, cruising on the Solent and the S Coast of the UK
Re: Aluminium Grab Rails
I beleive any alu part of equipment for marine use is anodized.
If this is regarding to a 25 mm outer diameter straight pipe, the fittings may probably fit for a new rf pipe. Such may be bought in a metal store.
Pancho
Segelnummer: 3344
Båtnamn: Pancho
Inlägg av Pancho »
Thanks Maya - I will try to find some.
James Baker
